New customer? Sign up now and get $5 OFF your first order. Sign Up & Save $5
TBS6910 DVB-S2 Dual Tuner Dual CI HD Satellite PCIe TV Card, for Pay-TV
Model#: TBS6910
Weight: 300 g(s)
Successor
Description:
TBS6910 DVB-S2 Dual Tuner Dual CI PCIe Card is a twin tuner digital satellite TV for watching or recording two different channels from two different frequencies simultaneously. You can use one tuner to watch TV channel while using another tuner to record/watch another channel from another transponder/ satellite at same time. TBS6910 is integrated with two CI slots, inserting the correct CAM and subscription smartcard into the CI slot makes it possible to watch encrypted pay TV.
Main Features
  • Watch satellite TV & listen to radio on PC
  • DVB-S/S2 SD or HD TV receiving
  • Dual tuner and dual CI slots for decrypt the encrypted TV
  • Time shifting to pause live TV
  • Blindscan support
  • Unicable/one cable compatible
Application
  • Data receiving
  • Media monitoring
Specifications:
  • Frequency range: 950~2150 MHz
  • Input level: -69-23dBm
  • 2x DVB-S2/S 8PSK QPSK demodulator
  • Symbol rate:
    • DVB-S QPSK 1~45Msps
    • DVB-S2 QPSK/8PSK 1~45Msps
  • Carrier capture range: ±10MHz
    • DVB-S2 CCM:
      • QPSK +1/4, 1/3, 2/5, 1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 8/9, 9/10
      • 8PSK +3/5. 2/3. 3/4. 5/6. 8/9. 9/10
    • DVB-S
      • QPSK +1/2, 2/3, 3/4, 5/6, 7/8
  • Support data burst & tone burst
  • Support DiSEqC2.X and motor
  • Dual CI slot
  • Dimension: 145 * 104.5mm (length x height)
  • Max Power consumption: 15W
System Requirements
  • Windows 2000/XP/Vista/7/8/10 or Linux OS
  • Available PCI Express x1, x4, x8 or x16 slot
  • Satellite dish and LNB
Package Contents
  • 1 x TBS6910
  • 1 x DC line
