New customer? Sign up now and get $5 OFF your first order. Sign Up & Save $5
2026 TurBoSight Black Friday—The Biggest Deals of the Year Are Here! / Save Big Now —Limited offer:20/11/2026-1/12/2026
TBS6528 Multi Standard Tv Tuner Common Interface (CI) PCI-e Card,DVB-S2/S, DVB-T2/T,DVB-C2/C, DVB-S2X and ISDB-T
Model#: TBS6528
Weight: 350 g(s)
Successor
Description:
TBS6528 is a PCI Express TV tuner card that supports multiple digital TV standards, including DVB-S2/S, DVB-T2/T,DVB-C2/C, DVB-S2X and ISDB-T. It is built with Common Interface which allows insertion of CAM and smartcard for pay TV, so it is a good choice for watching/recording digital cable HD TV on PC. What's more, with this multi-standard TV tuner card, it is much easier to switch between different digital TV signals. You just need to plug another signal cable instead of taking out the card from your server.
View More
  • Support DVB-S/S2/S2X, DVB-T/T2/C(ITU-T J.83 Annex A/B/C)/C2, ISDB-T
  • Watch & record TV/ radio programs on PC
  • Common Interface (Single CI) Support
  • SD or HD TV receiving
  • Data receiving
  • Media monitoring
Specifications:
ISDB-T
COFDM demodulator and FEC decoding
Support 3 layers decoding
TMCC decoding
Support differential demodulation
AC1 and AC2 decoding
DVB-T2 and T2-Lite
Receiving channel: VHF band, UHF band
Bandwidth: 1.7, 5, 6, 7, 8MHz
FEC: QPSK, 16QAM, 64QAM,256QAM
Code rate: 1/2, 2/3, 3/4, 5/6, 7/8
DVB-C2 COFDM demodulator(16_QAM to 4096_QAM)
FEC(LDPC/BCH) decoder
Bandwidth: 6MHz, 7MHz, 8MHz
DVB-C and ITU-T J.83 Annex B QAM demodulator
FEC decoder
1 to 7.2MSymbol/s
DVB-S/S2/S2X
symbol rates: 1-45Msps
FEC:
    DVB-S/S2
                     QPSK:   1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 8/9, 9/10
                      8PSK:   3/5, 2/3, 3/4, 5/6, 8/9, 9/10
                  16APSK:   2/3, 3/4, 4/5, 5/6, 8/9, 9/10
                  32APSK:   3/4, 4/5, 5/6, 8/9, 9/10
    DVB-S2X
                     QPSK:   13/45, 9/20, 11/20
           2_4_2_APSK:   100/180, 104/180
                      8PSK:   23/36, 25/36, 13/18
               8_8_APSK:   90/180, 96/180, 100/180, 18/30, 20/30
                  16APSK:   26/45, 3/5, 28/45, 23/36, 25/36, 13/18, 140/180, 154/180
    4_12_16rb_APSK:   2/3
      4_8_4_16_APSK:   128/180, 132/180, 140/180
Power consumption
Input/ Power: 12V/6~15W
temperature 0°~ 60°
Other information:
Digital TV signal (DVB-S2/S/S2X /DVB-T2/T/DVB-C2/C/ISDB-T)
Dimension:
TV tuner card size 140mm*93mm
Net weight 93Gram
Gift Box Size 200*130*30mm
Weight 191Gram
Package Contents 1 x TBS6528
1 x power cable
1x IEC Connector
