TBS6504H Multi-Standard Quad (4SAT+ 4Ter/Cable) Tuner PCI-E Card
Model#: TBS6504H
List Price: US$349.00
Price:
299.00
14%
Save:US$50.00 ( 14% OFF )
Weight: 550 g(s)
Ship From: China
You will earn 299 Points for buying this product. How to Use ?
Qty:
Unit(s)
Description:
TBS6504H is a Octa(4SAT+ 4Ter/Cable)PCI express TV tuner card that supports multiple digital TV standards including DVB-S2X/S2/S/T2/T/C2/C (J.83A/B/C)/ISDB-T/C /ATSC1.0, four RF IN is independent with each other, it supports both quad DVB-S2X/S2 and quad DVB-T2/T/C2/C standard at the same time, which allows to receive/record channels from satellite and terrestrial/cable at the same time . With this multi-standard TV tuner card, it is much easier to switch between different digital TV signals.
TBS6504H not only supports normal DVB-S2X/DVB-S2/S QPSK, 8PSK which is supported by normal satellite receivers, but also supports CCM, VCM, 16APSK, 32APSK Stream Mode, which most satellite receiving devices can't support. With use of dedicated TBS tools, those special streams can be captured.
Main Features
  • DVB-S/S2/S2X, DVB-T2/T, DVB-C2/C (ITU-T J.83 Annex A/B/C), ISDB-T, ISDB-C, ATSC1.0
  • Support VCM, CCM, QPSK, 8PSK, 16APSK, 32APSK;
  • Up to 173M/bps(TS Data Rate)
  • High-definition video, real-Time and scheduled video recording
  • High sensitivity Tuner for the best digital TV reception
Model TBS6504H
Connector PCI-E
8 x RF (4 satellite tuner + 4 Ter/Cable tuner)
DVB-S2/S QPSK 1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 8/9, 9/10
8PSK 3/5, 2/3, 3/4, 5/6, 8/9, 9/10
16APSK 2/3, 3/4, 4/5, 5/6, 8/9, 9/10
32APSK 3/4, 4/5, 5/6, 8/9, 9/10
DVB-S2X QPSK 1/4,1/3, 2/5 (S2-MODCODs)
8/9, 9/10 (S2-MODCODs)
11/45, 4/15, 14/45, 7/15 8/15, 32/45
8PSK (8APSK-L) 3/5, 2/3, 3/4, 5/6, 8/9 (S2-MODCODs)
7/15, 8/15, 26/45, 32/45
16APSK 2/3, 3/4, 4/5, 5/6, 8/9 (S2-MODCODs)
7/15, 8/15, 26/45, 3/5, 32/45
32APSK (32APSK-L) 3/4 ,4/5,5/6, 8/9, 9/10 (S2-MODCODs)32/45 ,11/15,7/9 ,(2/3)
Symbol rate 1 ~ 45Msymb/s
DVB-T2 and T2-Lite Receiving channel: VHF band, UHF band
Bandwidth: 1.7, 5, 6, 7, 8MHz
1/32, 1/16, 1/8, 1/4, 1/128, 19/128 and 19/256 guard intervals
16, 32, 64, 128 and 256QAM modulations
Code rate: 1/2, 3/5, 2/3, 3/4, 4/5 and 5/6
DVB-T 6, 7 and 8MHz channel bandwidths
2 and 8K FFT
QPSK, 16 and 64QAM
1/2, 2/3, 3/4, 5/6 and 7/8 code rates
DVB-C2 6 and 8MHz channel bandwidths
1/64 and 1/128 guard intervals
16, 64, 256, 1024, 4096 QAM
2/3, 3/4, 4/5, 5/6, 8/9 and 9/10 code rates
DVB-C 1.7 to 7.2 Msym/s
0.15 roll-off factor
J.83B (ITU-T J.83 v3.0 Annex B) 5.056941, 5.360537, 5.6 Msym/s
0.18 and 0.12 roll-off factor
64 and 256QAM
ISDB-T 6, 7 and 8MHz channel bandwidths
2 and 8K FFT
QPSK, 16 and 64QAM
ISDB-C 5.274 Msym/s
0.13 roll-off factor
64 and 256QAM
TSMF (Transport Streams Multiplexing Frame)
ATSC 1.0 6MHz channel bandwidths
8VSB modulation
2/3 code rate
Power consumption
Input/ Power: 12V/6 ~ 18W
temperature 0° ~ 60°
Other information:
Digital TV signal (ISDB-T/DVB-T2/C2/S2X/S2/T/C/S)
TV tuner card size 12.1cm * 10.8cm * 2cm
Package Contents 1 x TBS6504H
1 x DC cable
