What Do Our Customers Say?
este equipos soporta atras?? es posible que lo vendan con el software astra instalado??
Does this equipment support backwards? is it possible to sell it with the astra software installed?? "
Englishyonathan
function normally, ubuntu compatible "
EnglishRistianto
More Customer Testimonials
New Arrival
TBS2952 Lite Live TV to IP Streaming Server Chassis
The Live TV to IP Streaming Server Chassis is a compact and powerful solution designed for live TV streaming over IP networks. Equipped with two PCIe slots, this chassis supports a variety of live TV tuner PCIe cards...
Price: US$750.00
TBS2824 1U 24 Channels 4K H.265 / H.264 HDMI Video Encoder
TBS2824 is a professional 1U 24 channels 4K HDMI Video Encoder, which facilitates high-quality content streaming and display. It can handle up to 4K@30Hz HDMI input and has the ability to stream content to numerous popular...
Price: US$3,900.00
TBS2602V2 H.264/H.265 3G-SDI to IP Video Encoder
TBS2602V2 3G-SDI Video Encoder is a professional high-definition video encoder that is equipped with one channel 3G-SDI input, dual H.264/H.265 encoded streams output via RJ45 interface. What’s more, it supports SDI loop out,...
Price: US$229.00
TBS6324 Quad 3G-SDI PCIe Encoder
TBS6324 quad 3G-SDI PCIe encoder allows capturing and encoding four separate 3G/HD/SD-SDI sources simultaneously. It supports up to 1080P@60HZ input and H.265/H.264 1080P@60fps video encode. It is an ideal device for those who...
Price: US$799.00
BUNDLE DEAL!  Buy 2 x TBS6916 Hexadeca Tuner Card, get 1 x TBS3102 for free
TBS6916 is a DVB-S2X/S2/S hexadeca tuner card, it not only supports to receive SD/HD digital TV channels from 16 different satellite transponders simultaneously, but also supports CCM, ACM, VCM and Multi Input Stream, which is...
Price: US$1,198.00
TBS6032 + Kylone 16 QAM DVB-C Modulator PCIe Card
TBS6032 16 QAM DVB-C modulator card adopts advanced modulation technology and works as a DVB-C signal generator. It supports to be fed with any DVB resources, network IP streams or other digital resources, and then output DVB-C...
Price: US$699.00
TBS2812 1U 12 Channels 4K H.265 / H.264 HDMI Video Encoder
TBS2812 is a professional 1U 12 channels 4K HDMI Video Encoder that enables high-quality content streaming and display. It supports up to 4K@30Hz HDMI input and can stream content to various popular online platforms such as...
Price: US$2,100.00
TBS812X 4K@30fps 12 HDMI to DVB-C/DVB-T/ASI Trans-Modulator Advanced Encoding
TBS812X , the new Ultra HD Multi-Standard Trans-Modulator series is a versatile and comprehensive solution designed to meet diverse broadcasting needs. This product series includes three distinct models, each supports to output...
TBS2816 Comix Pro 8 / 16 Channels 4K H.265 / H.264 HDMI Video Encoder
TBS2816 Comix Pro is a professional 1U 16 channels 4K HDMI Video Encoder that enables high-quality content streaming and display. It is capable of handling up to 4K@30Hz HDMI input and can stream content to various popular ...
TBS6522H Multi-Standard Quad (2SAT+ 2Ter/Cable) Tuner PCI-E Card
TBS6522H is a Quad tuner PCI express TV tuner card that supports multiple digital TV standards including DVB-S2X/S2/S/T2/T/C2/C (J.83A/B/C)/ISDB-T/C /ATSC1.0, four RF IN is independent with each other, it supports both dual...
Price: US$229.00
TBS8510-Lite IPTV Video Transcoder
The TBS8510-Lite IPTV video Transcoder is capable of handling 15~20 HD channels compression simultaneously. Equipped with powerful H.264 and H.265 encoding capabilities, this transcoder ensures superior video quality and...
Price: US$2,799.00
TBS2952 MOI Pro MAX IPTV Streaming Server
MOI Pro MAX is a new professional IPTV streaming server powered by Intel Quad Core solution. It can receive live TV signal using built-in TV tuners and stream the channels further through Ethernet to various clients' devices,...
Price: US$850.00
TBS2808 Comix 4K@30fps HDMI Video Encoder
TBS2808 Comix is a professional 8 channels 4K HDMI Video Encoder that enables high-quality content streaming and display. It supports maximum of 4K@30Hz HDMI input and can stream to popular online social media platform, such as...
TBS2640V2 8/16 Channels 4K H.265/H.264 HDMI Video Encoder
TBS2640V2 is an 8/16 channels 4K UHD H.265 & H.264 HDMI Video Encoder, supports max 3840 x 2160P@30fps, It supports 8/16 channels HDMI stream of H.264/H.265 encoding output and the AAC audio format. From any HDMI input source,...
Price: US$1,600.00
TBS2604V2 4K UHD HD H.265 & H.264 HDMI Video Encoder
TBS2604V2 is a 4K UHD H.265 & H.264 HDMI Video Encoder, capable of up to max 3840 x 2160P@30fps. It supports to encode with dual streams and streaming via IP,the main stream and the sub-stream can be encoded into different...
Price: US$229.00
TBS6909-X V2 + Kylone   DVB-S2X/S2/S Octa Tuner PCIe Card
Kylone licence valid activation time: Within one year from the date of order. (example: order date 2023.11.15, valid time: 2023.11.15~2024.11.15) TBS6909-X V2 is a powerful DVB-S2X/S2 and annex M octa tuner card with PCI...
Price: US$849.00
