New customer? Sign up now and get $5 OFF your first order. Sign Up & Save $5
TBS690A 4 Input DVB-ASI Capture Card, ASI to IP conversion
Model#: TBS690A
Price:
650.00
Weight: 400 g(s)
Ship From: China
You will earn 650 Points for buying this product. How to Use ?
Qty:
Unit(s)
Qty.Range(unit) Price(per unit) Discount
1 US$650.00 No
2-5 US$646.28 0.5722%
6+ US$644.42 0.8584%
Description:
The TBS690A is a 4-channel DVB-ASI capture card designed to receive DVB transport streams, supporting both single-program and multi-program inputs.
TBS690A is ideal for high-density applications requiring up to four ASI inputs, the input channels can run independently. With minimal power consumption, TBS690A is tailored for industrial applications where reliability is an option.
View More
  • DVB-ASI input
  • Compatible with DVB Standard
  • Four receiver channels on the same PCI-e card
  • Full DVB-ASI throughput of 140 Mbps per channel
  • Bandwidth can be divided as required between the ports
  • Signal quality sensing support in hardware
  • IPTV Servers
  • ASI to IP conversion
  • Datacasting and monitoring
  • Electronic Program Guides (EPG's)
  • Broadcast TV
Specifications:
Model TBS690A
Interface PCI-E x1
Input 4x ASI embedded Video/Audio
Form Factor Standard-height
Connector BNC
Data input DVB-ASI Transport Stream (MPEG-2, H.264, HEVC/H.265 or JPEG2000 compliant transport stream)
Video Formats DVB ASI Coaxial, DVB Transport Stream
Video Interfaces DVB-ASI at 140Mb/s
Receive FIFO Size 4 KB per channel
OS and Driver Windows 2000/XP/Vista/7/8/10 or Linux
Power 390mA & 5V
temperature 0 ~ 60℃
Dimension 11.5 * 12 * 2.1cm
Weight 120g
