New customer? Sign up now and get $5 OFF your first order. Sign Up & Save $5
2026 TurBoSight Black Friday—The Biggest Deals of the Year Are Here! / Save Big Now —Limited offer:20/11/2026-1/12/2026
TBS5881 DVB-T2/T/C TV Tuner CI USB box+SMIT Irdeto CAM CI Module
Model#: TBS5881+Irdeto
Weight: 600 g(s)
Description:
(一)TBS5881 DVB-T2/T/C TV Tuner CI USB box
Description:
TBS5881 is the successor of the TBS5880, which is a hybrid digital TV external box have both DVB-T2/T tuner and DVB-C tuner with USB connection, it supports DVB-T/DVB-T2 and DVB-C. You can use it for watching or recording digital terrestrial or cable TV on laptop or desk computer.
TBS5881 DVB-T2/T/C TV Tuner CI USB box also integrated with CI slot to makes it possible watch Pay TV (encrypted channels), simply by inserting the correct CAM and subscription smartcard into the CI slot, The unique TBS MCE tool can read pay TV channels. The manufacturer provides both Windows BDA driver and Linux driver up to the latest kernel. The unique TBS MCE tool makes it easy to read CAM/Smartcard on Windows7 Media Center, thus your subscription TV can be watched/ recorded on Windows7 Media Center. On Linux platform, you can also watch payTV with correct software. TBS5881 is compatible with Windows7 Media Center, MediaPortal, DVBlink, DVBDream, DVBViewer, ProgDVB, Skynet, TSreader, XBMC,MythTV,VDR and many other popular softwares.
Descriptions:
TBS5881 USB DVB-T2/T/C TV Box CI is a hybrid TV tuner box built with Common Interface support, which allows you to watch and recode Free to Air/Clear TV programmers also can watch and recode encrypt programmers via insert correct CAM and smartcard in its CI slot. There are one DVB-T2/T TV tuner and the other DVB-C TV tuner for you to choose between digital Terrestrial TV Channel and digital Cable TV Channel. The appropriate software to be provided such as: MediaPortal and its plugins, you may stream terrestrial and cable TV contents to your iPhone, iPad or iPod.
Watch digital TV & listen to radio on PC
Recode digital TV programmers on PC
CI slot for insert CAM and smart card to decrypt the encrypted Pay TV
Connect with USB
DVB-T2/T/C SD or HD TV receiving
Real time and scheduled program recording (PVR)
Time shifting to pause live TV
Common Interface (CI) Support
Specifications:
Support PLP( Physical Layer Pipe)
For DVB-T2/T
Receiving channel: VHF band and UHF band
Channel bandwidth: 6, 7, 8 MHz
DVB-T2/ T modulation type: QPSK, 16QAM, 64QAM, 256QAM
Code rate: 1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 7/8
Guard interval:1/4, 1/8, 1/16, 1/32, 1/64, 1/128, 19/128, 19/256
Intermediate frequency
IF mode: low IF
Center IF frequency: 3 ~ 5 MHz
Note: default 4MHz
RF-input impedance 75Ω (IEC-DIN female)
RF-output impedance 75Ω (IEC-DIN male)
Single CI
For DVB-C
Fully compliant with DVB-C and ITU J83 A/C specifications
Receiving frequency: 47~862 MHz tuning range
Input level: -65~-10dBm
16QAM, 32QAM, 64QAM, 128QAM and 256QAM support
Symbol Rate: 0.87 to 9Mbaud
Single CI
System Requirements:
Windows 2000/XP/Vista/7/8/10 or Linux
DirectX9.0 or later version
Available USB port
Dualcore CPU
1GB RAM or above
Graphic card with at least 64MB RAM
Package Content:
1x TBS5881
1x Power adapter
1x USB cable
1x remote control
1x AC line
(二)SMIT Irdeto CAM CI Module
Description:
This SMIT Irdeto Cam CI Module is ideal and designed to work with transmissions encrypted in Irdeto from the following broadcasters; Optus, SelecTV, MySat, PBS, DFH Network, Praetorium, Redlight TV, Inxworld, UPS Direct (Hungary), Canal Digitaal (Netherlands), Greek Nova, Satisfaction TV, SCT, Private Spice, Conto TV, Pink Plus, ART (on Nilesat), Al Jazeera Sport Theme X & more!
Adopting ASIC chip with proprietary intellectual property right:
Embedded 32-bit CPU (ARM7TDMI)
Adopting advanced 0.18-micron technology
Advanced language development environment
Supporting subsequent development of value-added services
Descrambling: Supporting common descrambling algorithm of Europe
DVB-CI interface: Compatible with DVB-CI / PCMCIA
Smart Card interface: ISO7816
Specification:
Dimensions: PCMCIA type II
Interface protocols of the host: In full compliance with DVB-CI Profile 1 protocol;
External interface of IC card: Build-in SmartCard reader, in compliance with ISO7816 protocol;
Operating system: Embedded Linux system with proprietary intellectual property rights;
Internal descrambler: Integrated universal DVB descrambler;
MPEG DEMUX: Multi-channel SECTION and PID filter configurable through software;
Enclosure structure: Latest compact structure and design for assembly;
Compatible with MPEG2 & MPEG4 Receivers
