What Do Our Customers Say?
Hi, can you tell me, how much this device please? We are from Mexico, we need 2 devices like this. Thank you "
EnglishJose Tohom
este equipos soporta atras?? es posible que lo vendan con el software astra instalado??
Does this equipment support backwards? is it possible to sell it with the astra software installed?? "
Englishyonathan
More Customer Testimonials
New Arrival
TBS6331R-ASI Professional DVB-ASI Capture Card
TBS6331R-ASI is a high-quality, PCIe x1 (Gen 2) DVB-ASI capture card. Combining a single DVB-ASI input for superior workflow efficiency with reliable, high-performance 24/7 capture and low power consumption, the TBS6331R-ASI...
Price: US$149.00
TBS6331R-SDI 3G-SDI Video Raw Data Capture Card
TBS6331R-SDI is a high-quality, PCIe x1 (Gen 2) raw data capture card. It features one 3G/HD/SD-SDI input that supports capturing uncompressed, real-time video at full HD resolutions of up to 1920x1080P@60Hz. Additionally, this...
Price: US$129.00
TBS6302T 4K@60fps Dual HDMI Input Encoding PCIe Card
TBS6302T is a professional 4K UHD HDMI video encoding card featuring two HDMI 2.0 inputs. Each HDMI port supports up to 3840 x 2160P@60Hz input and H.265 / H.264 encoding. It is ideal for low-bandwidth streaming without...
Price: US$799.00
TBS2808X 8 Channels 4K 30Hz H.265 / H.264 HDMI Video Encoder
TBS2808X is a professional 8 channels 4K HDMI video encoder that enables high-quality content streaming and display. It supports 8 channels 4K@30Hz HDMI input with real-time 4K@30FPS encoding. TBS2808X can stream to popular...
Price: US$1,500.00
TBS2808SDI 8 Channels 1080P@60fps SDI Video Encoder
TBS2808SDI is a high-definition multi-channel SDI video encoder that supports 8 independent SD/HD/3G-SDI inputs simultaneously and delivers H.264/H.265 encoded streams through a single RJ45 interface. TBS2808SDI supports...
Price: US$1,750.00
TBS2804SDI 4 Channels 1080P@60fps SDI Video Encoder
TBS2804SDI is a high-definition multi-channel SDI video encoder,which supports 4 independent SD/HD/3G-SDI inputs and H.264/H.265 encoded streams output via single RJ45 interface. TBS2804SDI supports up to 4-channel...
Price: US$990.00
TBS2616 16 Channels 1080P HDMI Video Encoder
TBS2616 HDMI video encoder is a professional high-definition video encoder, which not only supports 8 channels 4K or 16 channels H.265 encoding, but also supports multiprotocol output, each channel supports simultaneous output...
Price: US$3,200.00
TBS2804X 4 Channels 4K 30Hz HDMI Video Encoder
TBS2804X is a professional 4 channels 4K HDMI Video Encoder that enables high-quality content streaming and display. It supports maximum of 4K@30Hz HDMI input and can stream to popular online social media platform, such as...
Price: US$950.00
TBS5210 DTMB TV Tuner USB Box
TBS5210 is an external DTMB TV tuner card with USB2.0 interface. It's ideal for watching SD and HD channels on your PC. Through the USB interface, you can easily plug the TBS5210 DTMB TV Tuner into your desktop or laptop PC. With...
Price: US$69.00
TBS6322 Dual 3G-SDI PCIe Encoder
TBS6322 , a dual 3G-SDI PCIe encoder, allows capturing and encoding two separate 3G/HD/SD-SDI sources simultaneously. It supports up to 1080P@60HZ input and H.265/H.264 1080P@60fps video encoding. It is an ideal device for those...
Price: US$439.00
TBS260B pro IP to ASI converter
The IP to ASI Converter is an advanced signal conversion solution designed for broadcasters, cable operators, and other professional video applications. With robust hardware and intuitive software, this device seamlessly converts...
Price: US$750.00
TBS6314R Quad HDMI Raw Data Video Capture Card
TBS6314R is a PCIe Gen2 x4 raw data video capture card of superior quality and equipped with 4 HDMI inputs supporting uncompressed real-time video capturing at full HD resolution up to 1920x1080@60Hz. With the support of popular...
Price: US$249.00
TBS2952 Lite Live TV to IP Streaming Server Chassis
The Live TV to IP Streaming Server Chassis is a compact and powerful solution designed for live TV streaming over IP networks. Equipped with two PCIe slots, this chassis supports a variety of live TV tuner PCIe cards...
Price: US$750.00
TBS2824 1U 24 Channels 4K H.265 / H.264 HDMI Video Encoder
TBS2824 is a professional 1U 24 channels 4K HDMI Video Encoder, which facilitates high-quality content streaming and display. It can handle up to 4K@30Hz HDMI input and has the ability to stream content to numerous popular...
Price: US$3,600.00
TBS2602V2 H.264/H.265 3G-SDI to IP Video Encoder
TBS2602V2 3G-SDI Video Encoder is a professional high-definition video encoder that is equipped with one channel SD/HD/3G-SDI input, dual H.264/H.265 encoded streams output via RJ45 interface. What’s more, it supports SDI loop...
Price: US$229.00
TBS6324 Quad 3G-SDI PCIe Encoder
TBS6324 quad 3G-SDI PCIe encoder allows capturing and encoding four separate 3G/HD/SD-SDI sources simultaneously. It supports up to 1080P@60Hz input and H.265/H.264 1080P@60fps video encode. It is an ideal device for those who...
Price: US$799.00
