TBS6704 ATSC/ Clear QAM Quad Tuner PCIe Card,receiving digital ATSC, 8VSB and Clear QAM cable TV on PC
Model#: TBS6704
Price:
199.99
Weight: 350 g(s)
Ship From: China
You will earn 200 Points for buying this product. How to Use ?
Qty:
Unit(s)
Qty.Range(unit) Price(per unit) Discount
1 US$199.99 No
2-4 US$194.43 2.7779%
5+ US$188.88 5.5558%
Description:
TBS6704 is an ATSC quad tuner PCIe card for receiving ATSC, 8VSB and Clear QAM cable TV on PC. This quad tuner card allows you to watch and record up to 4 over-the-air (OTA) digital terrestrial/ Clear QAM HD TV channels at the same time, which is ideal for enterprise IPTV streaming solution.
* ATSC is mainly used in North America and South Korea.
Receive digital ATSC, 8VSB and Clear QAM cable TV on PC
Quad tuner card for watching/ recording 4 channels at the same time
High sensitivity ATSC quad tuner for the best digital TV reception
MPEG-2 & H.264 HDTV support
Time shift & schedule recording support
Windows & Linux driver support
Specifications:
8VSB demodulation, compliant with America ATSC, built-in forward error correction function
256/64QAM demodulation, compliant with OpenCable specifications
ATSC / Digital Cable (QAM) Input: 75 Ohm
Channel bandwidth: 6, 7, 8 MHz
Tuning range: 44MHz ~ 1002MHz
Interface: PCI Express (PCIe)
Dimensions: 140*68.7 mm
Power: ~10W
System Requirements:
Windows 2000/XP/Vista/7/8/10 or Linux
Pentium 4 2.0 GHz, Pentium M 1.3 GHz
For HDTV: 2.6 GHz multi core processor
Hard disk with min. 1 GB free capacity
Sound and graphics card with support for DirectX 9 or higher
CD/DVD drive for software installation
Package Contents:
1 x TBS6704
1 x Low profile bracket
1 x F connector
Parse Time: 0.257 - Number of Queries: 233 - Query Time: 0.18259239196777
