19% Up toOFF 2024 TurBoSight Black Friday Deals! Biggest Sale of the Year!Don't Miss Out! Limited offer: 27/11/2024-6/12/2024
MS98E 9 x 8 Satellite Multiswitch for FTA Receiver
Model#: MS98E
Weight: 1100 g(s)
Description:
MS98E provides 9 inputs that can connect eight SATV signals, one ANT signal or FM broadcast simultaneously. It has 8 outputs that allow you to connect 8 receivers and watch different channels at the same time. The 9x8 satellite multiswitch is designed to combine all satellite signals.
8 satellite IF+ 1 Terrestrial inputs
Versions for 8 subscriber outputs
Built in Amplifiers circuit to compensate cable loss
Specifications:
Model MS98E
No.of Inputs 8 Sat. ,1 Terr.
No.of Outputs 8
Frequency  Sat.(MHz) 950-2200
Terr. (MHz) 47-862
Tap Loss/Gain Sat.(Loss)(dB) 2
Terr.(Loss)(dB) 2
Isolation Switching(dB) 30
Sat.(Out-Out)(Tap) (dB) 30
Terr.(Out-Out)(Tap) (dB) 26
Rejection(dB) 27
Return Loss In (dB) 12
Out(dB) 9
Output Level Sat.(IMD3-35dB)(Tap)(dBuv) 100
Terr.(IMD3-60dB)(Tap)(dBuv) 88
Power Supply(Vac/Hz) 110-260/47-63
DC Current Consumption(mA) 60
Max.Current Pass to LNB(mA) 1200
Input/Output Connector 75ohm F-( f )
Dimension(mm)
Weight(kg)
