TBS6590 Multi Standard Dual Tuner Dual CI PCI-e Card, DVB-S2/S, DVB-T2/T,DVB-C2/C, DVB-S2X, for Pay TV
Model#: TBS6590
Price:
199.99
Weight: 300 g(s)
Ship From: China
You will earn 200 Points for buying this product. How to Use ?
Qty:
Unit(s)
Qty.Range(unit) Price(per unit) Discount
1 US$199.99 No
2-5 US$195.97 2.0101%
6+ US$192.96 3.5176%
Description:
TBS6590 multi standard dual tuner dual CI card is a twin tuner card for watching or recording two different channels from two different frequencies simultaneously. TBS6590 supports multiple digital TV standards, including DVB-S2/S, DVB-T2/T,DVB-C2/C, DVB-S2X and ISDB-T. It is built with 2 Common Interface which allows insertion of CAM and smartcard for pay TV, so it is a good choice for watching/recording digital HD TV on PC. What's more, with this multi-standard TV tuner card, a switchover between different digital TV signals is much easier, you just need to plug another signal cable instead of taking out the card from your server.
Support DVB-S/S2/S2X 、 DVB-T/T2/C(ITU-T J.83 Annex A/B/C)/C2 、 ISDB-T
Watch & record TV/ radio programs on PC
Common Interface (Dual CI) Support
SD or HD TV receiving
Data receiving
IPTV streaming
Media monitoring
Digital content distribution
Specifications:
ISDB-T COFDM demodulator and FEC decoding
Support 3 layers decoding
TMCC decoding
Support differential demodulation
AC1 and AC2 decoding
DVB-T2 and T2-Lite Receiving channel: VHF band, UHF band
Bandwidth: 1.7, 5, 6, 7, 8MHz
FEC: QPSK, 16QAM, 64QAM,256QAM
Code rate: 1/2, 2/3, 3/4, 5/6, 7/8
DVB-C2 COFDM demodulator(16_QAM to 4096_QAM)
FEC(LDPC/BCH) decoder
Bandwidth: 6MHz, 7MHz, 8MHz
DVB-C and ITU-T J.83 Annex B QAM demodulator
FEC decoder
1 to 7.2MSymbol/s
DVB-S/S2/S2X symbol rates: 1-45Msps
FEC:
DVB-S/S2
QPSK: 1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 8/9, 9/10
8PSK: 3/5, 2/3, 3/4, 5/6, 8/9, 9/10
16APSK: 2/3, 3/4, 4/5, 5/6, 8/9, 9/10
32APSK: 3/4, 4/5, 5/6, 8/9, 9/10
DVB-S2X
QPSK: 13/45, 9/20, 11/20
2_4_2_APSK: 100/180, 104/180
8PSK: 23/36, 25/36, 13/18
8_8_APSK: 90/180, 96/180, 100/180, 18/30, 20/30
16APSK: 26/45, 3/5, 28/45, 23/36, 25/36, 13/18, 140/180, 154/180
4_12_16rb_APSK: 2/3
4_8_4_16_APSK: 128/180, 132/180, 140/180
Power consumption
Input/ Power: 12V/10~18W
temperature 0-60℃
Other information:
Digital TV signal (DVB-S2/S/S2X /DVB-T2/T/DVB-C2/C/ISDB-T)
Dimension:
TV tuner card size 104.5mm*150mm
Net weight 137G
Gift Box Size 17.7*16*3CM
Weight 245G
Package Contents 1 x TBS6590
1x DC line
2x IEC Connector
TBS6590 Multi Standard Dual Tuner Dual CI PCI-e Card Data Sheet
Parse Time: 0.282 - Number of Queries: 751 - Query Time: 0.23280334472656
