TBS6528 is a PCI Express TV tuner card that supports multiple digital TV standards, including DVB-S2/S, DVB-T2/T,DVB-C2/C, DVB-S2X and ISDB-T. It is built with Common Interface which allows insertion of CAM and smartcard for pay TV, so it is a good choice for watching/recording digital cable HD TV on PC. What's more, with this multi-standard TV tuner card, a switchover between different digital TV signals is much easier, you just need to plug another signal cable instead of taking out the card from your server.
Multi-standard tuner card
Watch & record satellite TV/ radio programs on PC
Common Interface (Single CI) Support
Fast scanning functionality for all media, including efficient blind scan for satellite and cable
Flexible tuner interface
Low power cunsumption: Automatic spectral inversion detection for all media
Data receiving
IPTV streaming
Media monitoring
Digital content distribution
Specifications:
ISDB-T | 6,7 and 8 MHz bandwidth |
Partial reception supported | |
Carrier recovery:±600 kHz | |
Timing recovery:±200 ppm | |
DVB-T2 and T2-Lite | Bandwidth: 1.7, 5, 6, 7 or 8 MHz |
DVB-T2 versus DVB-T automatic detection | |
Carrier recovery: ±600 kHz | |
Timing recovery: ±200 ppm | |
DVB-T | Bandwidth: 6, 7, 8 MHz |
Supports all C.R.; G.I.;LP and HP streams | |
Advanced terrestrial channel equalizer | |
DVB-C2 | Notch management |
Advanced cable channel equalizer | |
DVB-C | DFE equalizer specific for cable network |
Carrier recovery: ±11% of Symbol rate | |
Timing recovery: ±1000 ppm | |
DVB-S/S2/S2X | Enhanced immunity to co-channel interferers |
Programmable carrier recovery range | |
Power consumption | |
Input/Power | 12V/15W(Max) |
temperature | 0°~ 60° |
Other information:
System Requirements | Windows XP / Vista/ 7/8/10, Linux |
Available PCI Express x1, x4, x8 or x16 slot | |
Digital TV signal (DVB-S2/S/S2X /DVB-T2/T/DVB-C2/C/ISDB-T) | |
Dimension: | |
TV tuner card size | 140mm*93mm |
Net weight | 93Gram |
Gift Box Size | 200*130*30mm |
Weight | 191Gram |
Package Contents | 1 x TBS6528 |
1x DC line | |
1x IEC Connector |
