TBS6680 PCIe DVB-C Dual Tuner Cable TV Card with Dual CI Slot (The Successor:TBS6290SE)
US$198.99
TBS6618 DVB-C TV Tuner CI PCIe Card (The Successor:TBS6290SE)
US$98.99
  • item#: TBS6680
  • Price:
    198.99
  • Start from: 1 Unit(s)
  • Weight: 790 g(s)
  • Ship From: China
  • You will earn 199 Points for buying this product. How to Use ?
Qty.Range(unit) Price(per unit) Discount
1 US$198.99 No
2-5 US$193.99 2.5126%
6+ US$188.99 5.0253%
10+ Please contact us.
* Discounts may vary based on options above
Options:
Optional:
  • Shipping Methods
  • Payment Methods
Relative Products
Description:
TBS6680 is a Dual tuner digital cable TV internal card with Dual common interface. It can be used for watching clear QAM or encrypted Pay TV (By inserting the correct CAM and subscription smartcard into the CI slot, encrypted pay TV will be available). Windows BDA driver is provided and Linux driver is also available. TBS6680 is compatible with MediaPortal, DVBlink, DVBDream, DVBViewer, ProgDVB, Skynet, TSreader, XBMC,MythTV, VDR and many other popular softwares.
TBS6680 PCIe DVB-C Dual Tuner Dual CI Card, built with two Common Interfaces which allows insertion of CAM and smartcard for pay TV, is a good choice for watching/recording digital cable HD TV on PC.
Watch Cable TV & listen to Radio on PC
2 x DVB-C SD or HD TV Receiving simultaneously
2 x Common Interface Support
Specifications:
Fully compliant with DVB-C and ITU J83 A/B/C specifications
Receiving Frequency: 47~862 MHz Tuning Range
Input level: -65~-10dBm
16QAM, 32QAM, 64QAM, 128QAM and 256QAM Support
Symbol Rate: 0.87 to 9Mbaud
Dual CI Slot
Standard Profile TV Card Size: 145x104mm (Length x Height)
TV Card Weight: 122 Gram
Package Gift Box Size: 205x140x50mm (Length x Width x Height)
Package Gift Box Weight: 0.75KG
System Requirements:
Windows 2000/XP/Vista/7/8/10 or Linux
DirectX9.0 or later Version
Available PCI Express x1,x4, x8 or x16 slot
Cable TV connection
For HDTV:
Dualcore CPU
1GB RAM or Above
Package Content:
1 x TBS6680 PCIe DVB-C Dual Tuner Dual CI Card
1 x remote control
1 x IR receiver
1 x Software CD
Product Reviews:
Average rating:
5 (based on 5 reviews)
Recent Reviews
  • By Marius
  • Jun 25, 2015
Dear sirs
in the review of product TBS6905 DVB-S2 Quad Tuner PCIe Card you mentioned " Even more if you want to make full use of the recording power of TBS6905, you may record four whole TS (Transponder Stream), one of which could contains maximum ten, twelve SD or HD TV channels into your PC hard disk, in other words, you will be able to record up to 48 channels with TBS6905 in the same time. This feature contributes a lot especially when you are building up HTPC or IPTV streaming server." .
I'm very intersted if the same solution (Recording multiple channels as ones and how many as maximum? is posible for a CABLE TUNER DVB-C? and what is the best model in this way ?
Thansk you in advance
Was this review helpful?
(0)|(0)
Reply
Dear Marius,
Thanks for your questions at first. Compared with TBS6905 DVB-S2 quad tuner, TBS6680 is dual one. So two transponders,which means it depends on how many channels in two transponders.
Best Regards!
BUYDVB Online Store
By hellen Jun 26,2015
  • By Boris
  • Verified Buyer
  • Aug 08, 2014
Hi, does this card support CI+ standard ?
(0)|(0)
Reply
Dear Boris,
Thanks for the info at first.
Sorry that TBS tuners don't support CI+ Standard at present.
Best Regards!
BUYDVB Online Store
By hellen Aug 11,2014
  • By Shat
  • Verified Buyer
  • Jul 24, 2014
Hi!
Can i use TBS6680 for recieve DVB-T2 signal? I need dual T2 card with CI, I cant see this card on your website.
(0)|(0)
Reply
Dear Shat,
Thanks for your info. TBS6680 is a Dual tuner digital cable TV internal card with Dual common interface, not for DVB-T2/
And TBS will release DVB-T2/T/C Dual Tuner Dual CI PCIe Card TBS6290 next month. You can pay close attention to the latest news on our online store.
Best Regards!
BUYDVB Online Store
By hellen Jul 25,2014
  • By wilson
  • Verified Buyer
  • Jul 17, 2014
Hi do you give support how get cam I'd after buy product?
Regards
(0)|(0)
Reply
Dear Wilson,
Thanks for your info at first. Yes, we provide full support. If there is any question when testing, you can email us or support@tbsdtv.com for help.
Best Regards!
BUYDVB Online Store
By shipper Jul 18,2014
  • By Ronaldo Ramos
  • Apr 19, 2014
Hello I am interested in a tuner TBS6680 PCIe DVB-C I wonder if they send to Brazil as would be the price of the product plus shipping?
(0)|(0)
Reply
Dear Sir,
Yes, we can ship TBS6680 to Brazil by DHL. DHL shipping cost is about US$37.
Please don't forget to provide your CPF number when you place the order.
Best Regards
BUYDVB Online Store
By Apr 24,2014
Write a Review:
Tell us what you think about this item, share your opinion with other people. Please make sure that your review focus on this item. All the reviews are moderated and will be reviewed within two business days. Inappropriate reviews will not be posted.
Have any question or inquire for this item? Please contact Customer Service. (Our customer representative will get back shortly.)
    Indicates required fields*
    Rating:
    Your Name: *
    Enter your Reviewer Nickname
    Your Email: *
    Review Title: *
    Verify code: *
Search Feedback
  • Did you find what you were looking for?
  • If you need help or have other feedback for Customer Service. Click here
Recently Sold items
    Customers who bought this product also purchased...
    Newsletter
    for Wholesale
    about the latest offers and deals Subscribe today!
