TBS5980 USB DVB S2 TV QBox CI+UKT1A1 Universal Unicable high gain & low noise Twin LNB
US$119.98
TBS5922SE DVB-S2 TV Tuner USB Box (The Successor:TBS5520)
US$59.99
TBS5980 USB DVB S2 TV QBox CI (The Successor:TBS5990)
US$79.99
  • item#: TBS5980+UKT1A1
  • Price:
    119.98
  • Start from: 1 Unit(s)
  • Ship From: China
  • You will earn 120 Points for buying this product. How to Use ?
  • Shipping Methods
  • Payment Methods
Relative Products
Description:
(一)TBS5980 USB DVB S2 TV QBox CI
Description:
TBS5980 USB DVB S2 TV QBox CI is a digital satellite external TV Tuner box with USB connection for watching and recording digital satellite TV on PC. With integrated CI slot, it can be used for watching Free to Air TV and Pay TV(By inserting the correct CAM and subscription smartcard into the CI slot, encrypted pay TV will be available). Both Windows BDA driver and Linux driver up to the latest kernel are provided.
The unique TBS MCE tool makes it possible to read CAM/Smartcard on Windows7 Media Center, thus your satellite subscription TV can be watched/recorded on Windows7 Media Center. On Linux platform, you can also watch paytv by using correct software. TBS5980 USB DVB S2 TV QBox CI is compatible with Windows7 Media Center, MediaPortal, DVBlink, DVBDream, DVBViewer, ProgDVB, Skynet, TSreader, XBMC,MythTV,VDR and many other popular softwares.
With use of appropriate software, e.g. MediaPortal and its’ plugins, you may stream satellite TV contents to your IPhone, IPAD or IPOD. The built in hardware blindscan capability allows you to scan satellite programs without knowing exact transponder details, this is especially useful for hunting unknown satellite feeds.
Please check the PCIe interface equivalent device: TBS6928SE DVB-S2 CI TV Tuner card
Main Feature:
Watch Satellite TV & listen to Radio on PC
DVB-S2/DVB-S SD or HD TV Receiving
Unicable/One Cable compatible
Common Interface Support
Blindscan
High reliability
Specification:
Receiving Frequency: 950~2150 MHz Tuning Range
Input level: -69~-23dBm
DVB-S2/DVB-S 8PSK QPSK Demodulator
Symbol Rate:
DVB-S QPSK 1~45Msps
DVB-S2 QPSK/8PSK 1~45Msps
Carrier Capture Range: ±10MHz
8PSK Puncture codes: 3/5,2/3,3/4,5/6,8/9,9/10
QPSK Puncture codes: 1/2,3/5,2/3,3/4,4/5,5/6,8/9,9/10.
Support Data Burst & Tone Burst
Support DiSEqC2.X and Motor
Single CI Slot
TV Box Size: 103x88x22mm (Length x Width x Height)
TV Box Weight: 200 Gram
Package Gift Box Size: 210x175x55mm (Length x Width x Height)
Package Gift Box Weight: 726 Gram
System Requirements:
Windows 2000/XP/Vista/7/8/10 or Linux
DirectX9.0 or later Version
Available USB2.0 Port
Satellite Dish and LNB
For DVB-S:
1GHz CPU or above
256MB RAM or above
Graphic Card with at least 16MB RAM
For DVB-S2 HDTV:
Dualcore CPU
1GB RAM or Above
Package Content:
1 x TBS5980
1 x remote control
1 x Power Adapter
1 x USB Cable
1 x AC line
(二)UKT1A1 Universal Unicable high gain & low noise Twin LNB
Description:
UKT1A1 universal LNB is used to feed up to two different receivers, with high stability, high gain, yet low noise figure, this UKT1A1 LNB allows reception of signals with the highest possible signal level and quality. Use this with your Free To Air receiver for excellent and superior reception.
● Low noise figure
● Easy installation
● Low power consumption
● High quality weather protection
Specification:
● Low Band I/P Frequency Range :10.7 ~ 11.7 GHz
● LO Frequency: 9.75 GHz
● Noise Figure : 0.7 dB Max.
● High Band I/P Frequency Range :11.7 ~ 12.75GHz
● LO Frequency : 10.6 GHz
● LO Initial Accuracy: +/- 1.0MHz
● LO Temperature Drift : +/- 2.5MHz
● LO Phase Noise @ 10K Hz: -90 dBc / Hz
● SCR Conversion Gain: 57 dB Min.
● Legacy Conversion Gain :55 dB Min.
● Gain Variation : +/- 0.75 dB/27MHz
● Image Rejection : 40 dB Min.
● Cross-pole Isolation : 20 dB Min.
● O/P 1 dB Compression Point : 0.0 [ min. ]
● O/P VSWR : 2.5 : 1
● Output Impedance : 75 (F-type)
● IF Channel bandwidth :60 MHz
● Output IF Channel 1 (SCR0) :1210 MHz
● Output IF Channel 2 (SCR1):1420 MHz
● Output IF Channel 3 (SCR2) :1680 MHz
● Output IF Channel 4 (SCR3) : 2040 MHz
● Channel isolation :20 dB Min.
● Legacy Ports :1
● SCRs’ Control Signals :DiSEqC command extension based on EN-50494
● Legacy Switch Voltage / Frequency Control : <14.2 (V) , >15 (H) Volts / 0/22 KHz (H/L)
● Legacy 22k sensitivity : 220 mV [min.]
● DC Power : 230mA /13.5V
● Working Temperature : - 30°C~ + 60°C
● Weight : 350g
Product Reviews:
Write a Review:
Tell us what you think about this item, share your opinion with other people. Please make sure that your review focus on this item. All the reviews are moderated and will be reviewed within two business days. Inappropriate reviews will not be posted.
Have any question or inquire for this item? Please contact Customer Service. (Our customer representative will get back shortly.)
    Indicates required fields*
    Rating:
    Your Name: *
    Enter your Reviewer Nickname
    Your Email: *
    Review Title: *
    Verify code: *
Search Feedback
  • Did you find what you were looking for?
  • If you need help or have other feedback for Customer Service. Click here
Recently Sold items
    Newsletter
    for Wholesale
    about the latest offers and deals Subscribe today!
