TBS5881 DVB-T2/T/C TV Tuner CI USB box+SMIT Irdeto CAM CI Module
US$134.98
TBS5281 DVB-T2/T/C Dual Tuner TV USB Box (The Successor:TBS5881)
US$79.99
US$79.99
TBS5220 USB DVB-T2 / T / C Tuner TV Stick
US$48.99
  • item#: TBS5881+Irdeto
  • Price:
    134.98
  • Start from: 1 Unit(s)
  • Weight: 600 g(s)
  • Ship From: China
  • You will earn 135 Points for buying this product. How to Use ?
    Quantity: Unit(s)
      • Shipping Methods
      • Payment Methods
      Relative Products
      Description:
      (一)TBS5881 DVB-T2/T/C TV Tuner CI USB box
      Description:
      TBS5881 is the successor of the TBS5880, which is a hybrid digital TV external box have both DVB-T2/T tuner and DVB-C tuner with USB connection, it supports DVB-T/DVB-T2 and DVB-C. You can use it for watching or recording digital terrestrial or cable TV on laptop or desk computer.
      TBS5881 DVB-T2/T/C TV Tuner CI USB box also integrated with CI slot to makes it possible watch Pay TV (encrypted channels), simply by inserting the correct CAM and subscription smartcard into the CI slot, The unique TBS MCE tool can read pay TV channels. The manufacturer provides both Windows BDA driver and Linux driver up to the latest kernel. The unique TBS MCE tool makes it easy to read CAM/Smartcard on Windows7 Media Center, thus your subscription TV can be watched/ recorded on Windows7 Media Center. On Linux platform, you can also watch payTV with correct software. TBS5881 is compatible with Windows7 Media Center, MediaPortal, DVBlink, DVBDream, DVBViewer, ProgDVB, Skynet, TSreader, XBMC,MythTV,VDR and many other popular softwares.
      Descriptions:
      TBS5881 USB DVB-T2/T/C TV Box CI is a hybrid TV tuner box built with Common Interface support, which allows you to watch and recode Free to Air/Clear TV programmers also can watch and recode encrypt programmers via insert correct CAM and smartcard in its CI slot. There are one DVB-T2/T TV tuner and the other DVB-C TV tuner for you to choose between digital Terrestrial TV Channel and digital Cable TV Channel. The appropriate software to be provided such as: MediaPortal and its plugins, you may stream terrestrial and cable TV contents to your iPhone, iPad or iPod.
      Watch digital TV & listen to radio on PC
      Recode digital TV programmers on PC
      CI slot for insert CAM and smart card to decrypt the encrypted Pay TV
      Connect with USB
      DVB-T2/T/C SD or HD TV receiving
      Real time and scheduled program recording (PVR)
      Time shifting to pause live TV
      Common Interface (CI) Support
      Specifications:
      Support PLPPhysical Layer Pipe)
      For DVB-T2/T
      Receiving channel: VHF band and UHF band
      Channel bandwidth: 6, 7, 8 MHz
      DVB-T2/ T modulation type: QPSK, 16QAM, 64QAM, 256QAM
      Code rate: 1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 7/8
      Guard interval:1/4, 1/8, 1/16, 1/32, 1/64, 1/128, 19/128, 19/256
      Intermediate frequency
      IF mode: low IF
      Center IF frequency: 3 ~ 5 MHz
      Note: default 4MHz
      RF-input impedance 75Ω (IEC-DIN female)
      RF-output impedance 75Ω (IEC-DIN male)
      Single CI
      For DVB-C
      Fully compliant with DVB-C and ITU J83 A/C specifications
      Receiving frequency: 47~862 MHz tuning range
      Input level: -65~-10dBm
      16QAM, 32QAM, 64QAM, 128QAM and 256QAM support
      Symbol Rate: 0.87 to 9Mbaud
      Single CI
      System Requirements:
      Windows 2000/XP/Vista/7/8/10 or Linux
      DirectX9.0 or later version
      Available USB port
      Dualcore CPU
      1GB RAM or above
      Graphic card with at least 64MB RAM
      Package Content:
      1x TBS5881
      1x Power adapter
      1x USB cable
      1x remote control
      1x AC line
      (二)SMIT Irdeto CAM CI Module
      Description:
      This SMIT Irdeto Cam CI Module is ideal and designed to work with transmissions encrypted in Irdeto from the following broadcasters; Optus, SelecTV, MySat, PBS, DFH Network, Praetorium, Redlight TV, Inxworld, UPS Direct (Hungary), Canal Digitaal (Netherlands), Greek Nova, Satisfaction TV, SCT, Private Spice, Conto TV, Pink Plus, ART (on Nilesat), Al Jazeera Sport Theme X & more!
      Adopting ASIC chip with proprietary intellectual property right:
      Embedded 32-bit CPU (ARM7TDMI)
      Adopting advanced 0.18-micron technology
      Advanced language development environment
      Supporting subsequent development of value-added services
      Descrambling: Supporting common descrambling algorithm of Europe
      DVB-CI interface: Compatible with DVB-CI / PCMCIA
      Smart Card interface: ISO7816
      Specification:
      Dimensions: PCMCIA type II
      Interface protocols of the host: In full compliance with DVB-CI Profile 1 protocol;
      External interface of IC card: Build-in SmartCard reader, in compliance with ISO7816 protocol;
      Operating system: Embedded Linux system with proprietary intellectual property rights;
      Internal descrambler: Integrated universal DVB descrambler;
      MPEG DEMUX: Multi-channel SECTION and PID filter configurable through software;
      Enclosure structure: Latest compact structure and design for assembly;
      Compatible with MPEG2 & MPEG4 Receivers
      Product Reviews:
      Write a Review:
      Tell us what you think about this item, share your opinion with other people. Please make sure that your review focus on this item. All the reviews are moderated and will be reviewed within two business days. Inappropriate reviews will not be posted.
      Have any question or inquire for this item? Please contact Customer Service. (Our customer representative will get back shortly.)
        Indicates required fields*
        Rating:
        Your Name: *
        Enter your Reviewer Nickname
        Your Email: *
        Review Title: *
        Verify code: *
      Search Feedback
      • Did you find what you were looking for?
      • If you need help or have other feedback for Customer Service. Click here
      Recently Sold items
        Newsletter
        for Wholesale
        about the latest offers and deals Subscribe today!
